Old 08-22-2014, 07:07 AM
deuce168 deuce168 is offline
vicon.dle error
Very interesting problem I'm having trying to establish a connection from Vizard 5 to Vicon Nexus.
3 Things tend to happen:
15% of the time, a connection is established successfully to the Nexus, which is the most frustrating part of this problem.
The rest of the time, it either gets stuck during viz.add("vicon.dle", 0, VICON_IP) and requires a manual termination of the script from task manager, or it generates an error saying connection could not be established.
Any help would be greatly appreciated, and any extra information you might need can be provided. Thanks in advance!
Old 08-22-2014, 08:00 AM
Unless you're using an older version of Nexus it's likely the streaming protocol is not compatible with the Vizard plug-in.
Do you have Vicon Tracker? If so you could use VRPN to stream the data to Vizard. The last time I checked Nexus did not support VRPN. You might ask Vicon support to see if that's changed.
Old 06-03-2015, 06:49 AM
willpower2727 willpower2727 is offline
open source method to stream Nexus to Vizard
I created an open source method to stream Nexus to Vizard. Hopefully it might be useful to you.
https://github.com/willpower2727/Vicon2WorldViz
Error using CMF export from 3ds max to cal3d in some avatars disbeat Vizard 4 04-15-2014 11:40 PM
Polhemus Liberty Latus connecting error Yang Vizard 2 02-13-2013 11:52 AM
** ERROR: Link failed (source linkable is invalid) mhead10 Vizard 2 10-04-2012 01:18 PM
5DT glove ultra error 5dt.dls failed kabk Vizard 2 05-05-2009 12:43 PM
Loading morph mesh error. vEsotu Vizard 2 03-14-2009 06:29 PM
