Old 05-04-2009, 01:38 PM
kabk kabk is offline
5DT glove ultra error 5dt.dls failed
Why do I get an error message with this script
when using the 5dt glove ultra?
The error is:
** ERROR: Failed to load plug-in: '5dt.dls' ?
PORT_5DT_USB = 0
sensor = viz.add('5dt.dls')
import hand
h = hand.add(sensor)
h.setEuler(0,-90,0)
#h.leftHand()
tips = []
S = 0.01
for x in range(5):
tips.append( viz.add('white_ball.wrl',scale=(S,S,S),color=viz.B LUE) )
def UpdateFingerTips():
for x in xrange(5):
mat = h.getFingerTip(x)
tips[x].setPosition(mat.getPosition())
tips[x].setQuat(mat.getQuat())
vizact.ontimer(0,UpdateFingerTips)
import vizcam
cam = vizcam.PivotNavigate()
cam.setCenter(0,0,0)
cam.setDistance(0.5)
viz.clearcolor(viz.GRAY)
Old 05-04-2009, 06:47 PM
Have you tried other values for the PORT_5DT_USB variable?
Old 05-05-2009, 12:43 PM
The error you are receiving means that the actual DLL failed to load. This means the DLL is missing or that one of its dependencies are missing. Make sure that the 5dt.dls is located in the Vizard/plug-ins folder and that fglove.dll is located in your Vizard/bin folder.
intersense with 5DT glove sjp Vizard 2 04-06-2009 07:22 AM
intersense: Failed to set control word on \\.\COM1 OueOue Precision Position Tracker (PPT) 2 01-18-2007 12:51 PM
Use of 5DT Ultra left handed glove pattie Vizard 1 08-26-2006 12:59 PM
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 04:08 PM
5DT Data Glove 5 Ultra Flexure Question bjgold Vizard 1 07-25-2006 02:58 PM
