Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 04-10-2014, 11:05 AM
gmu12 gmu12 is offline
Joystick Nav Vizard4 vs Vizard 5
Hello there,
I recently updated to Vizard 5, but now the code I was using for my joystick no longer works. I've tried following the joystick instructions for Vizard 5, but I can get it the joystick to function like I need it to (i.e., like it did in Vizard 4).
Any help would be appreciated. Thanks!
The code I used in Vizard 4 is below. Vizard 5 gives the error "no module named sid":
def mytimer(num):
		y = sid.get()[1]
		x = sid.get()[0]
		twist = (180.0 / math.pi) * (sid.aux()[3])
		if math.fabs(y) > 0.5:
			viz.move(0,0,-y*.021)
		if math.fabs(x) > 0.5:
			viz.move(x*.021,0,0)
		if math.fabs(twist) > 20:
			viz.rotate(viz.BODY_ORI,twist/50.0,0,0)
	viz.starttimer(1,0.001,viz.FOREVER)
	viz.mouse.setOverride(viz.ON)
Old 04-11-2014, 12:07 AM
The sid module for connecting to gamepad devices is quite old and has been removed from Vizard 5. The vizjoy module replaced sid and is documented in both Vizard 3 and 4. Now in Vizard 5, the recommended way to connect to a DirectInput compatible gamepad and joystick device is using the DirectInput plug-in.
Have you tried the navigation.py or other example scripts included with Vizard?
Old 04-14-2014, 11:23 AM
Thanks, that worked!
joystick, vizard 5.0
Realistic Light and Shadows Using Vizard and 3DS Max jde Vizard 4 07-13-2012 11:58 AM
joystick position nmohandes Vizard 2 01-16-2012 11:03 AM
