Old 01-08-2012, 04:06 AM
nmohandes nmohandes is offline
joystick position
Hi
I am writing a program and i need to take the joystick position when clicking on certain objects on the screen
like the user will select one object from the screen and then rotate it and then move the joystick to select another object ...
I have the code that have the position and move on empty screen
import vizjoy
import vizinfo
#IMPORTANT: Need to add a joystick. This will return the first detected joystick
joy = vizjoy.add()
#Add textures
hand = viz.addTexture('hand.jpg')
#Add the texture quad for the joystick position
joystick = viz.addTexQuad(viz.SCREEN)
joystick.setScale([0.3,0.3,1])
#Set the joystick texture to the dot
joystick.texture(hand)
JOY_CENTER_X = 0.5
JOY_CENTER_Y = 0.35
JOY_SCALE = 10.0
#Joystick position has changed, update dot
def joymove(e):
joystick.setPosition(JOY_CENTER_X+(e.pos[0]),JOY_CENTER_Y-(e.pos[1]))
#Set all the joystick callbacks
viz.callback(vizjoy.MOVE_EVENT,joymove)
How i can select one specific object on the screen ... do some action ( rotate) and then select another one ..
any ideas or hints
thank you
Old 01-11-2012, 02:47 PM
Take a look the viz.pick command. When you're not picking with the mouse you can specify the position on screen to perform the pick. In your case that's the quad position. Register a callback function using vizact.onupdate that calls the pick command every frame. If an object is returned then apply the action to it.
Old 01-16-2012, 11:03 AM
Thank you
I was able to pick using the joystick
def pickone(object):
object = viz.pick()
if object.valid():
pos = joystick.getPosition()
object.setEuler([90,0,0])
viz.callback(vizjoy.BUTTONDOWN_EVENT,pickone)
viz.callback(vizjoy.BUTTONUP_EVENT,buttonup)
changing the gain of a joystick during a program Saz Vizard 4 06-25-2009 04:49 AM
How to get the data from Logitech G25 racing wheel ? fuyonggang Vizard 4 12-18-2008 07:14 PM
writing joystick position to a data file Saz Vizard 3 12-17-2008 06:18 AM
Joystick Navigation Vinicius Lima Vizard 7 10-23-2007 11:42 AM
Facetracking and Immersion Joystick Vygreif Vizard 1 01-25-2006 11:56 AM
