Old 01-09-2014, 07:47 AM
zorgblaubaer zorgblaubaer is offline
Conveyor Belt demo
Hey everyone,
I am trying to get the Conveyor Belt demo to work with our system. I can grab the objects from the belt and let go of them again. But I can't seem to figure out how to get them counted towards the score. They are not getting recognized in the DropBin.update method.
Also, they are falling with a very high velocity and bounce of the ground or whatever they hit like a bouncy ball.
What am I doing wrong?
The only part of my code where I am interacting with the objects is this:
def updateGrabs():
	global grab
	if gripTracker.getButtonState() >= 2:
		if grab == False:
			# check to see if the hand/thermometer intersects with an object in the scene
			handPos = rightHandTracker.getPosition(viz.ABS_GLOBAL)
			# go through each item the list and find out if any are in range
			selectedItem = None
			selectedItemDistance = 0.2# set min distance
			for item in GrabObjects.grabObjects:
				# find the closest inside of that distance
				d = vizmat.Distance(handPos, item.getPosition(viz.ABS_GLOBAL))
				if selectedItemDistance > d:
					selectedItem = item
					selectedItemDistance = d
			if selectedItem:
				grab = viz.grab(rightHandTracker,selectedItem)
		if grab != False:
			grab.remove()
			grab = False
vizact.onupdate(0,updateGrabs)
Old 01-14-2014, 05:18 AM
I managed to solve both problems.
I got rid of the bouncyness by reseting the objects when the grab is removed:
    if grab != False:
	grab.getDst().reset()
	grab.remove()
	grab = False
I got the objects being recognized by not removing the DropBin bounding boxes but rather make them invisible (and I also remove the objects from the scene as soon as they are inside of a bin)
Apartment demo/texture demo pwsnow Vizard 10 10-05-2012 11:10 AM
PPT Demo mikestatic Precision Position Tracker (PPT) 1 09-23-2007 11:31 AM
demo of new hand.getFingerTip() halley Vizard 9 12-14-2006 01:40 AM
Glenn Kawesch, looking for demo GlennKawesch Vizard 2 10-19-2006 10:17 AM
using demo with intersense G-Chan Vizard 1 02-06-2006 03:05 PM
