Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 02-06-2006, 02:01 PM
G-Chan G-Chan is offline
using demo with intersense
Currently we have installed in our lab the is900 intersense tracker. I've been downloading the demos (Punch demo) and have been trying to have it work with the intersense system. I first load and send the configuration of our intersense constellation to the tracking system and it shows that it is tracking the devices (we have the cube and the wand), however when I run the demo on vizard I get the following:
File "PunchDemo_IC2_With_FISTHEIGHT.py", line 232 in mytimer
fistPos = data[0:3]
TypeError: Unsubscriptable object
** Error: failed to load plugin intersense.dls
Even when I try the manual demo for the head tracker I get the following:
**Error: Failed to set requested display mode
I suspect I may have skipped a step or need to detect something. Does vizard require some sort of driver for intersense that needs to be separately installed? Any help on this matter would be greatly appreciated. I am also currently using worldviz 2.50, if I upgrade it to 2.53 will I have to pay extra?
Thank you in advance,
George Chan
Sunlab, McMaster University
Old 02-06-2006, 03:05 PM
mspusch mspusch is offline
Hi George,
When using IS900 with Vizard, you should run the Intersense proram called IServer, to handle the different Intersense devices which are connected.
Vizard will load the Intersense devices 'one by one', the way they are listed in IServer (see Intersense docs about how to configure this).
so the first line
head = viz.add('intersense.dls')
will add the first Intersense device,
the second line
fist = viz.add('intersense.dls')
will add the second Intersense device, etc.
If you decide not to use the IServer, you need to specify the Intersense Port before you load the individual Intersense devices. Please add the following line of code BEFORE the individual viz.add('intersense.dls') statements:
PORT_INTERSENSE = 0
Port 0 is the port typically used by IS900, but it can also be other ports, just have a look at your windows port configuration to find out.
All best,
The WorldViz Team
P.S. Upgrades within versions (i.e. 2.5 to 2.53 is free). The only upgerade which will require either an active support contract or an upgrade charge is the upgrade to Vizard 3.0 as soon as this is available.
