Old 11-18-2013, 09:05 PM
spatnav spatnav is offline
Coordinates
I'm using vizard 3.0 (I have imported a maze from 3ds). I want to determine the coordinates of the maze I have created in 3ds that I have now input into vizard 3.0. Is there an easy way to do this?
Old 11-21-2013, 05:39 PM
If you want to determine the coordinates of certain points along the maze you could:
Vizard 3: Run a script and load the model, navigate to certain locations, and print out the viewpoint position.
Vizard 4: Open the model in Inspector, right click in the maze and choose Copy 3D Position. This is available in the Trial and Lite versions as well.
Texture Coordinates in a Cube Map mshukun Vizard 2 05-10-2013 12:31 PM
360 panorama image cube using as darts target and record the xy coordinates mshukun Vizard 2 03-14-2013 06:17 AM
Haptic touch texture coordinates yth Vizard 0 06-02-2012 03:40 AM
How do coordinates in IS900 thransform into coordinates in vizard's world jacky Vizard 1 08-11-2011 10:44 AM
viz.vertex coordinates lilio Vizard 6 05-16-2009 04:36 PM
