Old 07-22-2013, 06:38 AM
CompSci CompSci is offline
Scroll Bar for Text/Resize & Button Image
Does anyone know how I would add a scroll bar to a text box?
Also, how do I re-size and change the font/color of viz.addText3D and viz.addText?
Is it possible to viz.addTexture to a button?
Thank you
Old 07-23-2013, 05:54 AM
Thank you
For the last question I want to add an object to a button, is that possible?
Old 07-23-2013, 12:49 PM
You might want to look into wxPython or another Python add-on that's used for creating GUI applications to create a textbox that scrolls. Vizard's textbox does not support that functionality.
The command index (Help->Command Index) documents the commands available on node3D objects.
For text font/color:
<node3d:text3d>.font
<node3d:text3d>.fontSize
<node3d>.color
For button image:
<node3d:GUI:button>.downpicture
<node3d:GUI:button>.uppicture
Old 07-24-2013, 04:23 AM
<node3d>.color
For button image:
Ok, thanks, I will give this a try.
360 panorama image cube using as darts target and record the xy coordinates mshukun Vizard 2 03-14-2013 06:17 AM
Create Button or Text Chrissy2009 Vizard 1 07-15-2009 05:34 PM
View an image on the Fakespace HMD roman_suvorov Vizard 16 05-23-2008 07:51 AM
button problems cade_mccall Vizard 3 02-22-2007 09:48 AM
