Old 06-20-2013, 02:19 PM
Daniel Daniel is offline
Droplist for different scenes
Hello
It is possible to create a droplist to visualize different scenes, like in the i-SpaceDemo.exe.
This mean that when i select Scene1 in the droplist the Scene1.osgb loads, and when I select Scene2 in the droplist the Scene2.osgb loads.
I am a little bit lost with this problem
Old 06-24-2013, 02:17 PM
You could add the environment models to different scenes when the script loads and swap scenes in the droplist callback function:
gallery = viz.addChild('gallery.osgb', scene=1)
dojo = viz.addChild('dojo.osgb',scene=2)
dropList = viz.addDropList(parent=viz.ORTHO,scale=[0.75]*3)
dropList.addItems(['Gallery','Dojo'])
viz.link(viz.MainWindow.RightTop, dropList, offset=[-150,-50,0])
def changeScene(e):
	if e.object.getItem(e.newSel) == 'Gallery':
		viz.scene(1)
	if e.object.getItem(e.newSel) == 'Dojo':
		viz.scene(2)
vizact.onlist(dropList,changeScene)
Old 06-26-2013, 02:41 PM
It works great but is there a limit in the number of scenes/droplist? Because only let me put around 6 or 7 scenes. The other 3 or 4 (I want to put 10 scenes) appear in the droplist but don't change the scene when i select it the droplist
Old 06-27-2013, 09:54 AM
You can use up to six scenes at one time. If you need more environments you can remove what's in one of those scenes and load a new environment there.
Old 07-10-2013, 10:05 AM
There is no limit to the number of scenes you can use. For historical reasons, Vizard creates six scenes at startup. However, you can create more scenes using the viz.addScene() command.
Adding Objects to all Scenes jassel41 Vizard 1 11-29-2010 02:35 AM
displaying random scenes etc cl113 Vizard 1 05-10-2009 05:14 PM
Arranging Scenes in Correct Order utepbereed Vizard 1 11-21-2008 09:19 AM
environment maps, scenes, and you! vadrian Vizard 1 01-12-2005 04:04 PM
switching between scenes david Vizard 4 07-01-2003 06:05 PM
