Old 05-07-2009, 04:03 PM
cl113 cl113 is offline
Question displaying random scenes etc
i am a beginner and i am terrible at programming and am quite confused.
1. is there any way, after creating multiple scenes, that one can randomly select which scene to display using vizact.choice or something else?
2. does vizact.choice randomly choose from a list and then stop when all the list items have been chosen, or does it continue to choose from the list?
3. also, is there a specific command that allows you to reflect an object's position about a specific axis?
the online reference is not helping and any help would be much appreciated!!!!!!!!
Old 05-10-2009, 06:14 PM
You could randomly select a scene using the random module to generate a random integer and then set the scene to that number.
import random
#add three objects to three different scenes
duck = viz.add('duck.wrl',scene = 1)
wheelbarrow = viz.add('wheelbarrow.ive',scene=2)
wheelbarrow = viz.add('ball.wrl',scene=3)
viz.MainView.move(0,-1,-7)
def changeScene():
	num = random.randint(1,3)
	viz.scene(num)
vizact.ontimer(2, changeScene)
To get an objects position use
object.getPosition()
That will return a list with x,y,z position of the object.
Making buttons appear in scenes DBurks2818 Vizard 4 04-09-2009 03:25 PM
Arranging Scenes in Correct Order utepbereed Vizard 1 11-21-2008 10:19 AM
Random head movements VR_enthusiast Vizard 2 07-19-2006 12:59 PM
Random Seeds Vygreif Vizard 1 04-27-2006 10:21 PM
switching between scenes david Vizard 4 07-01-2003 07:05 PM
