Old 05-27-2009, 12:11 PM
yak yak is offline
Importing a 3d human model and getting it to interact.
I am trying to import a model from 3ds max and saved it as a .wrl however when i import it in vizard I can interact with it. I can only interact with the vizard model (vcc_male.cfg). How can I import a model into vizard and interact with it.
thank you
Old 05-27-2009, 02:51 PM
Are you saying you want to export you own avatar from Max with animations. If so you'll need to export to the Cal3D format. Here is a link to a tutorial on doing that.
http://download.gna.org/cal3d/docume.../tutorial.html
The Cal3D exporter for Max is available from our dowload page
http://www.worldviz.com/download/index.php?id=9
Old 05-30-2009, 08:05 PM
yak yak is offline
so Are you saying if I export the human 3d model as a Cal3D file, it will make the human 3d model be interactive in vizard.
Old 06-01-2009, 02:19 PM
You need to create animations for it in Max and export these with your Cal3D files to get an avatar you can load in Vizard with animations.
