Old 06-26-2012, 06:14 AM
NI_LAB NI_LAB is offline
Failed to load plug-in: 'immersion.dle'
Hi all,
I have just this one line in my code:
immersion = viz.add('immersion.dle')
but I get this error
** Loading Vizard2.py
** ERROR: Failed to load plug-in: 'immersion.dle'
** Load Time: 0.00 seconds
If I try to do this:
vrpn = viz.add('vrpn7.dle')
everything works fine, and both files are in the same folder.
What am I doing wrong?
Old 06-27-2012, 01:11 PM
Do you have Immersion's VirtualHand SDK installed on your system? It is required for the plugin to load.
Old 07-02-2012, 06:52 AM
Question
Thank you for your post.
But unfortunately I have installed the SDK, and still it does not work?!?
Any other ideas?
Old 07-06-2012, 03:41 AM
Which version of the VirtualHand SDK is installed, is it the latest one?
Old 07-31-2012, 06:33 AM
Hi again,
ok so after a while we tried this glove again.
We are making progress, but it still does not work.
What is working now:
- the DCU shows the cybertouch glove and its movements correctly
- in the DCU we can do the test stuff and the vibrators all work fine
- we can load the immersion.dle now (I installed the latest update VirtualHandSDKSetupV2_10.exe of the SDK from this site
The problem:
- When adding this line
glove = immersion.addCyberTouch()
we get this error:
immersion.dle Immersion Extension
** ERROR: Failed to connect to CyberTouch. Make sure Device Manager is running.
Initialization Failure NETWORK: APPEARS TO BE DISCONNECTED(-101) for C:\Program Files (x86)\Immersion Corporation\VirtualHand\
** ERROR: Failed to create extension sensor with immersion.dle
** Load Time: 0.23 seconds
The DCU is running, it shows a glove.
Could it lie in the fact that we use 32bit-Vizard, but only have 64bit-Virtual Hand SDK? If so, how can we solve it?
We have installed the VirtualHand SDK from the CD in this folder:
C:\Program Files\CyberGlove Systems\VirtualHand SDK
but the update installed itself into this folder:
C:\Program Files (x86)\Immersion Corporation\VirtualHand.
Old 07-31-2012, 06:39 AM
Ah and the version of the SDK is 3.1.1 (64bit)
Old 08-03-2012, 04:36 PM
Are you using a glove from Immersion or CyberGlove Systems?
If you are using a CyberGlove Systems glove, then you need to use the cyberglove.dle extension, instead of immersion.dle. Also, if you are running on a 64-bit machine, things get a little more complicated. You need to install the 64-bit drivers for the glove. However, Vizard is a 32-bit program, so you also need to manually place the 32-bit CyberGlove SDK DLLs (CGS_VirtualHandDevice.dll, CGS_VirtualHandCore.dll, etc...) in your Vizard script directory.
Old 10-09-2012, 03:45 AM
We are using a CyberGlove Systems CyberTouch glove.
Ok so I uninstalled everything again to clean everything up, there were 32bit and 64bit versions of the SDKs installed. I use the cyberglove.dle extension now, and I installed the 64bit glove drivers from the CD. I placed the SDK DLLs from
C:\Program Files\CyberGlove Systems\VirtualHand SDK\lib\winnt_386\Release
into the same directory where my .py file is, but now I again get the error
** ERROR: Failed to load plug-in: 'CyberGlove.dle'
But why? DCU is running, glove is shown and works perfectly fine, also the vibrator test. Just in vizard it does not work?!
Do I have to install the 32bit SDK again? But then that is version 2.10, and now I have 3.1.1. Or maybe I just placed the wrong DLLs in my script folder or so?
Old 10-16-2012, 02:13 AM
Question
No ideas? ==(
Old 10-23-2012, 02:15 AM
Ok it works now. I now use the 32bit version of the SDK.
Old 03-11-2019, 11:46 AM
anand.yadav anand.yadav is offline
Hello there, I am living in 2019 and facing the same problem. It is working perfectly in DCU not in vizard.
In my case virtual hand drivers are 64-bit and vizard is also of 64-bit.
After virtual hand driver installation DLL files are saved in vizard's directory automatically no manual work.
Still I am getting error message:
** ERROR: Failed to connect to CyberGlove. Make sure Device Manager is running.
** ERROR: Failed to create extension sensor with CyberGlove.dle
Any suggestion what to try to get it sorted!!
Failed to load jpeg mhead10 Vizard 2 03-20-2012 11:53 AM
ERROR: Failed to load .ive file turgutm Vizard 1 09-16-2010 05:16 AM
Failed to load wav file BrynJ Vizard 1 04-24-2008 09:35 AM
intersense: Failed to set control word on \\.\COM1 OueOue Precision Position Tracker (PPT) 2 01-18-2007 12:51 PM
