Old 04-23-2008, 12:41 PM
BrynJ BrynJ is offline
Question Failed to load wav file
Hello all,
I'm new to Vizard, so my apologies if I'm missing something obvious, but I have a rather strange problem.
I'm trying to add an audio file, for use with an avatar, like so:
sayhello = vizact.speak('hello.wav')
But I keep getting a 'failed to load wave file' error on execution - however the file is definitely present and correct as it's available for playback in the Resources pane.
Any ideas what might be going wrong?
Old 04-24-2008, 10:35 AM
We usually use 16-bit PCM wav files and they work fine. Would you mind posting the wav file or sending it directly to me at lashkari@worldviz.com, so I could take a look at it?
Read file....many issues Uttama_vizard Vizard 9 07-08-2008 03:16 PM
Can't load vrmls Jerry Vizard 1 10-06-2006 01:46 PM
File Path 4 Object Load softscan2 Vizard 1 09-23-2005 09:59 AM
number of textures to load lucalatini Vizard 2 05-12-2005 06:50 PM
