Old 04-10-2012, 01:10 PM
Gekitatsu Gekitatsu is offline
viz.collision enabled lag
Setup
-City enviorment (Buildings/tress/cars/etc)(As 1.ive file)
-Mainview placed at a location in the city.
Goal
Move the camera around the city without being able to move through any objects in the city.
Problem
When I add viz.collision(viz.On) to enable collision for MainView my framerate drops to 22 from 60. Anybody have any idea how to bring my framerate back up to 60 with a collision enabled mainview?
-Note The mainview is not linked to any objects.
Old 04-11-2012, 07:00 AM
Having a dense mesh can slow things down to a crawl if you try to do collisions with it. Instead it's common to build a much lighter collision mesh (eg, 10k polygons) for collisions. Hide the visibility of the collision mesh and disable collisions on the dense visible mesh.
Old 04-11-2012, 09:20 AM
Along with using a lower poly mesh for collision tests, you can also use the viz.OPTIMIZE_INTERSECT_HINT flag to speed up collision tests with a particular mesh:
model.hint(viz.OPTIMIZE_INTERSECT_HINT)
How to verify if texbox is enabled disbeat Vizard 1 02-09-2011 01:20 PM
MainView.setPosition ignored when collisions are enabled vTony Vizard 1 09-25-2008 09:12 AM
collision with physics enabled joeymax Vizard 2 04-17-2008 02:49 PM
