Old 02-08-2011, 08:19 PM
disbeat disbeat is offline
How to verify if texbox is enabled
Is there a way to check if a textbox is enabled? I see the methods for enabling and disabling, but how can I just check if it is enabled in a particular moment?
Thanks in advance,
Marco Simões
Old 02-09-2011, 02:20 PM
If you are going to disable and enable the textbox you can create a variable to keep track of it's state. If you need to check whether the textbox has focus use the <node3d:GUI>.getFocus() command.
Texbox deselecting TarkaDahl Vizard 3 08-26-2011 03:02 PM
Multiline texbox disbeat Vizard 1 02-09-2011 02:31 PM
MainView.setPosition ignored when collisions are enabled vTony Vizard 1 09-25-2008 10:12 AM
collision with physics enabled joeymax Vizard 2 04-17-2008 03:49 PM
