Old 04-05-2012, 07:27 PM
allanjjj allanjjj is offline
Unhappy Cannot moving AR model......
I would like to animate AR model by keyboard input after the model is shown by detecting marker. The model is shown correctly in the center of marker but it cannot move. It just sticks on the marker no matter what key I pressed. Here is the code:
ar = viz.add('artoolkit.dle')
camera = ar.addWebCamera()
marker = camera.addMarker('ar/patt.worldviz',width=1000)
wheel = viz.add('wheelbarrow.ive')
viz.link(marker,wheel)
moveForward = vizact.move(0,0,2,1)
moveBack = vizact.move(0,0,-2,1)
turnRight = vizact.spin(0,1,0,90,1)
turnLeft = vizact.spin(0,1,0,-90,1)
def mykeyboard(whichKey):
if whichKey == viz.KEY_UP:
wheel.addAction(moveForward)
elif whichKey == viz.KEY_DOWN:
wheel.addAction(moveBack)
elif whichKey == viz.KEY_LEFT:
wheel.addAction(turnLeft)
elif whichKey == viz.KEY_RIGHT:
wheel.addAction(turnRight)
viz.callback(viz.KEYDOWN_EVENT, mykeyboard)
Can anyone help me out? many thanks~
Old 04-08-2012, 07:48 PM
Darkmax Darkmax is offline
welcome to the forum.
Is because the viz.link, you need to make postTrans or preTrans or you can use these command <camera>.setGlobalMarker(marker) to make the marker the center of your virtual world and apply actions like you are doing instead of using the link, but with these you just can use one marker at the same time.
please use the code tags the next time when you want to show your code to maintain the spaces.
with setGlobalMarker
camera.setGlobalMarker(marker)
artoolkit
change a model between scenes? Darkmax Vizard 2 05-25-2010 03:14 PM
Importing a 3d human model and getting it to interact. yak Vizard 3 06-01-2009 02:19 PM
Stop moving after few seconds?? Chrissy2009 Vizard 8 05-10-2009 02:47 PM
Model sizes Pastscapian Vizard 15 10-07-2006 02:48 PM
