Old 01-09-2012, 08:10 AM
Andy Andy is offline
setParent with child of a 3dMax model
I have a 3dmax model with some subnodes and I want to set another node as a child of one of this subnodes.
I have a simple example file, why is the ball place in the center of the model and not in the center of the subnode? In Vizard 3 it works correctly. Any idea?
viz.clearcolor(viz.SKYBLUE)
viz.addChild('tut_ground.wrl')
viz.MainView.setPosition([0,1.8,-14])
ball = viz.add('ball.wrl')
ball.setScale(3,3,3)
node = viz.add('testChilddNode_4.IVE')
subNode1 = node.getChild('Quader02-GEODE')
subNode2 = node.getChild('Quader03-GEODE')
ball.parent(subNode2)
node.setPosition([0,3,0])
Old 01-09-2012, 05:28 PM
I ran your script and I get the same results with Vizard 3 and 4. The ball is centered around the small box at the top. Where are you expecting the ball to be positioned?
Old 01-10-2012, 01:13 AM
Hi
I have found the problem. I have a global config 'vozcore.cfg' an set 'viz.model.optimize = 1 '. If I do this, the ball is center around the big box at the bottom, if I set it to 0 it works like it should.
thanks
Importing a 3d human model and getting it to interact. yak Vizard 3 06-01-2009 02:19 PM
Model sizes Pastscapian Vizard 15 10-07-2006 02:48 PM
Pivot points for child objects in Vizard with 3ds Max Gladsomebeast Vizard 0 09-19-2006 11:21 AM
Child Object Rotation paulgoldberg Vizard 5 09-05-2006 11:33 AM
