Old 04-05-2011, 11:15 AM
rlh001 rlh001 is offline
Sending data to Vizard via UDP
I have a c# program and need to send xyz position data via the UDP port to control an avatar. Is there a way to Pickle my transmission in C# so that it will be understood by Vizard. Thanks
Old 04-05-2011, 05:14 PM
The following post contains a sample script showing how to send/receive raw UDP data within your script:
http://forum.worldviz.com/showthread.php?t=1126
This will be much better than trying to pickle the data within your C# program.
Access to Geometry Data in a c++ plugin for vizard. xabbu Plug-in development 1 01-16-2009 04:14 PM
Vizard & USB 5DT Data Glove rdotsch Vizard 4 07-26-2005 05:35 AM
