Old 07-25-2005, 07:27 AM
rdotsch rdotsch is offline
Question Vizard & USB 5DT Data Glove
I'm having trouble getting vizard to detect an USB 5DT Data Glove Ultra 5.
import hand
#Add the 5DT sensor
sensor = viz.add('5dt.dls')
At this point vizard looks for a glove on COM1. Changing this with a command such as
PORT_5DT = 2
does allow me to change to another serial port (COM2 in this case). But I can't get it to point to a data glove connected on USB0.
Doesn't 5dt.dls offer USB support? Or am I doing something wrong?
Thanks in advance,
Ron
Old 07-25-2005, 12:51 PM
The driver for the 5DT data glove was made before the USB version was released. We will update our driver within the next few days. I will let you know when it is finished.
Old 07-25-2005, 03:38 PM
That's great news! Thanks.
Ron
Old 07-25-2005, 06:23 PM
I've attached a modified version of the 5DT driver to this post. It includes two files: fglove.dll and 5DT.dls. Place the file fglove.dll in the [Vizard25]/bin directory. Place the file 5DT.dls in the [Vizard25]/plug-ins directory. To connect to a USB glove you will need to specify the USB port as following:
PORT_5DT_USB = 0
This will attempt to connect to a glove on USB0. We do not currently have a 5DT data glove to test this new driver with, so if you experience any problems please let me know immediately.
Old 07-26-2005, 05:35 AM
Wow! That's quick. Thank you very much, it works perfectly, without any problems at all.
Kind regards,
Ron
