Old 02-08-2011, 07:49 AM
Albert Russel Albert Russel is offline
Connect on the fly shapes
I would like to build complex shapes out of cubes and then make them behave as one solid body. The add command does not work for vizshapes:
AttributeError: 'VizPrimitive' object has no attribute 'split'
Is there another way to get the same result for vizshapes as in the carousel example?
Greetings, Albert
import vizshape
viz.move(0,0,-10)
cube1 = vizshape.addCube()
cube2 = vizshape.addCube()
cube1.add(cube2)
spinForever = vizact.spin(0,1,0, 90, viz.FOREVER)
cube1.addAction(spinForever)
Old 02-08-2011, 09:34 AM
You can set up parent/child relationships between vizshape objects:
import vizshape
viz.move(0,0,-10)
cube2.parent(cube1)
cube2.setPosition([0,2,0])
You could also make all your vizshape objects children of a group node and move the group node around:
import vizshape
group = viz.addGroup()
group.setPosition([0,1.5,10])
positions = [[0,0,1],[0,0,-1],[-1,0,0],[1,0,0]]
for position in positions:
	cube = vizshape.addCube(size=0.5)
	cube.parent(group)
	cube.setPosition(position)
group.addAction(spinForever)
Is it possible to have make my shapes have black borders? Renato Lima Vizard 2 11-13-2010 08:35 AM
Cyberglove left hand not able to connect llqqff Vizard 2 07-21-2010 11:47 AM
Show Physics Shapes bloswald Vizard 3 04-07-2010 03:16 PM
Head tracking, Flock of Birds and vizcave; how do I connect them? Arandia Vizard 2 08-26-2009 04:59 PM
PPT talk button error: Failed to connect to COM4 jpq Precision Position Tracker (PPT) 3 12-08-2005 02:36 PM
