Old 04-06-2010, 07:40 AM
bloswald bloswald is offline
Show Physics Shapes
I have many different objects in my augmented reality environment with different collide shapes. Is there a way to make the physics shapes visible or transparent? It would make debugging a lot easier if I could see the shapes somehow.
bloswald
Old 04-06-2010, 11:35 AM
Take a look at the collideBox and collideSphere examples in the following page:
http://www.worldviz.com/vizhelp/Shapes.htm
They show ways to do this for certain objects which are centered at 0,0,0.
Old 04-07-2010, 07:13 AM
Is there a way to do this for objects not centered at the origin? I am just curious about collideBoxes and collideSpheres mostly. I realize that showing a collideMesh might be difficult.
bloswald
Old 04-07-2010, 03:16 PM
You would have to adjust the position of the box or sphere used to visualize the collision area.
In the following example the avatar origin is at the bottom of his feet so the box does appear to be in the correct position. Hit the spacebar to adjust the position of the box.
viz.clearcolor(viz.SKYBLUE)
logo = viz.add('logo.wrl',pos=[-1,1.5,6],euler=[0,0,30])
logo.collideBox()
logo.add('box.wrl',alpha=.2,scale=logo.getBoundingBox(viz.REL_LOCAL).size)
avatar = viz.add('vcc_male.cfg',pos=[1,0,6],euler=[180,0,0])
avatar.collideBox()
box = avatar.add('box.wrl',alpha=.2,scale=avatar.getBoundingBox(viz.REL_LOCAL).size)
vizact.onkeydown(' ',box.setPosition,[0,.9,0])
import vizcam
viz.cam.setHandler(vizcam.PivotNavigate(center=[0,1,6],distance=5))
The collideMesh area is the same as the object itself so it is not necessary to build anything to visualize it.
Show flight path of balls snoopy78 Vizard 1 08-28-2009 02:57 PM
physics engine exception ad_astra Vizard 3 03-25-2009 11:31 AM
Physics and Haptics jalvarez Vizard 3 07-16-2008 03:03 PM
another physics question adimov Vizard 1 07-22-2004 03:56 PM
Physics engine question adimov Vizard 2 07-22-2004 12:33 PM
