Old 08-04-2010, 08:23 AM
malmct malmct is offline
Text Box
I'm trying to use a textbox for text entry. However, whenever I call .get() on the text box, it only returns an empty string, regardless of whats in the box.
class makeMenu:
	def __init__(self):
		#Menu Generation
		self.treadMenu=vizmenu.add()
		self.command=self.treadMenu.add("Commands")
		self.speed=self.treadMenu.add("Speed")
		#Command Box
		self.go=self.command.add(viz.BUTTON_LABEL,"GO")
		self.stop=self.command.add(viz.BUTTON_LABEL,"STOP")
		#Speed Box
		self.lspeed=self.speed.add(viz.TEXTBOX, "LEFT BELT SPEED:")
		self.rspeed=self.speed.add(viz.TEXTBOX, "RIGHT BELT SPEED:")
                          vizact.onbuttondown(trMenu.go, moveBuffer, trMenu.lspeed.get(), trMenu.rspeed.get())
def moveBuffer(lsp, rsp):
	print lsp
lsp is always an empty string.
Old 08-06-2010, 10:02 AM
The code below works. I'll find out why the values are not passed to the callback function the way you have it and get back to you.
import vizmenu
class makeMenu:
	def __init__(self):
		#Menu Generation
		#Command Box
		#Speed Box
trMenu = makeMenu()
def moveBuffer():
	print 'Left Belt Speed:  ',trMenu.lspeed.get()
	print 'Right Belt Speed: ',trMenu.rspeed.get()
vizact.onbuttondown(trMenu.go, moveBuffer)
Old 08-06-2010, 01:58 PM
The code you posted works as it should. When your callback function is registered through the vizact.onbuttondown command, the values in both text boxes are empty strings. Getting the textbox values at the time of the button press should be done in the callback function itself, as in my example.
Old 08-10-2010, 08:18 AM
That makes sense. Thank you very much.
Vizinfo box: help with aligning text Woosuk Jang Vizard 4 07-15-2010 04:01 PM
Informationboxes with text snoopy78 Vizard 3 07-16-2009 10:23 AM
adding 2D text via script V.shazzle Vizard 3 09-19-2005 02:45 PM
3d Text with Transparent Borders vjosh Vizard 3 12-01-2004 10:50 AM
