Old 09-19-2005, 12:54 PM
V.shazzle V.shazzle is offline
Send a message via AIM to V.shazzle
adding 2D text via script
In Vizard 2.53, what is the script equivalent of using 'Add Text' in the Resource box?
ie. 'Add Text' -> text name is 'sample text' - how would I do that in code?
thanks!
Old 09-19-2005, 02:04 PM
Here is sample code to add a text object to the screen.
MyText = viz.add(viz.TEXT3D,'Message',viz.SCREEN)
MyText.translate(0.5,0.5)
Old 09-19-2005, 02:31 PM
is there a way to add 2D text label or text that sticks to one positon on the screen regardless of the viewpoint?
for example: in Beginner's Tutorials - adding 2D and 3D text - Stuck to the world: 'White Text' stays in place while 'Yellow Text' moves around due to viewpoint change. How do I add something like 'White Text' via scripts?
Old 09-19-2005, 02:45 PM
The code in the previous post does just that. It adds a text object to the screen, then translates it to the center. The text will stay in the same place on screen, no matter where the viewpoint is.
