Old 05-18-2010, 04:34 PM
ruby21 ruby21 is offline
problem with collision
I have modelled a house in 3ds max and exported it to Vizard,but everytime it appears to show the back of the house and not the front?any ideas why?
i want to nagivate through the house from out to inside and having problems with the collisions codes.if i switch the collision.(viz. ON)..i cant seem to get in the house and when i switch it off.. i am going passed through everything as i don't want..as i want to bump in to things...
any ideas what code could be used..i really could do with some help..thankx..
Old 05-19-2010, 08:25 AM
I don't understand you question about viewpoint collision. Have you created an opening in the house that you can move in and out through?
Old 05-19-2010, 09:09 AM
ermm nah i haven't made an opening in the house..is it possible to make one in vizard.its my 1st time using vizard..
Old 05-19-2010, 05:32 PM
Darkmax Darkmax is offline
you have to make the opening (i.e. a door where you can enter) of the house, in your modeler program(3ds max).
Also you have to consider the normals of your polygons to make it see from outside and inside.
Collision detection Moh200jo Vizard 1 01-27-2010 07:39 AM
Collision problem: Balls fly through the wall Chrissy2009 Vizard 11 05-19-2009 04:38 AM
PPT causing height problem just alex Precision Position Tracker (PPT) 2 01-30-2009 09:50 AM
problem with collision detection paulpars Vizard 6 06-09-2006 06:03 PM
