Old 01-27-2009, 01:57 PM
just alex just alex is offline
PPT causing height problem
For some reason, whenever I have my PPT computer connected and active with my rendering computer, the default viewpoint becomes 2 or 3 times higher than a person should be. When I run the program without PPT going, the point of view spawns at a normal height. I'm wondering if it's a problem with my code (I got thrown headfirst into this level of programming)
import math
import vizmat
import vizinfo
from lookingat import LookingAt
#adds the ppt
PORT_PPT = 1
ppt = viz.add('vizppt.dls')
ppt.command(3,"",1,1,5) #scales ppt tracking on xyz axis
#collisions on
viz.collision(viz.ON)
view.rotate(0,1,0,90)
#gonna comment out the collision for now, it's registering when the avatar touches
#ground as a collision
#This function is called when a collision occurs
def mycollision(info):
	print 'Collided'
#Create a callback for a collision event
viz.callback(viz.COLLISION_EVENT, mycollision)
PORT_INTERSENSE = 2
isense = viz.add('intersense.dls')
tracker = viz.add('intersense.dls')
viz.tracker()
tracker.reset()
def mykeyboard(key):
	#If the R key is pressed, reset the head orientation
	if key in ['r','R']:
		tracker.reset()
#Create a keyboard callback
#Add the street and drop it a little bit to be below the avatars feet.
street = viz.add('objects/bspcity.bsp')
street.translate(0,-.2,0)
males = []
females = []
walking = []
whichturn = 0
#List the timers.
WALKING = 0
BLINDWALK = 1
BLINDLOOK = 2
MALEMEETING = 3
FEMALEMEETING = 4
SITTINGWOMAN=5
FREEZESITTER=6
THROWINGMAN =7
HOLDVIEW = 8
TIMING = 9
#Add the heads for the males.
maleheads = ['Male/heads/M-015-2L.vzf','Male/heads/M-056L.vzf', 'Male/heads/M-063L.vzf']
femaleheads = []
bodyparts = ['male_legs.cmx','male_torso_LS.cmx','male_shoes.cmx']
maleclothes = ['Male/clothes/male1.jpg','Male/clothes/male2.jpg','Male/clothes/male3.jpg']
#Make some avatars.
for i in range(3):
	male = viz.add('male.cfg')
	male.translate(i,0,0)
	male.visible(0,'male_head.cmx')
	male.face(maleheads[i])
	clothes = viz.add(maleclothes[i])
	for j in bodyparts:
		male.texture(clothes,j)
	males.append(male)
for i in range(3):
	female = viz.add('female.cfg')
	female.translate(i,0,0)
	females.append(female)
#Set up paramters for walking guy.
males[0].translate(0,0,-5)
males[0].rotate(0,1,0,-90)
males[0].whichturn = 0
males[0].set = [[1.5,0,-5],[1.5,0,15],[5,0,15],[-5,0,-5]]
males[0].end = 4
walking.append(males[0])
#Set up paramters for walking girl.
females[0].translate(1,0,-7)
females[0].rotate(0,1,0,-90)
females[0].whichturn = 0
females[0].set = [[1.5,0,0],[1,0,15],[2,0,15],[-5,0,-5]]
females[0].end = 4
walking.append(females[0])
#Add car.
#car = viz.add('objects/sport.wrl')
#Set up for meeting.
males[1].translate(-9,0,21)
females[1].translate(2,0,7)
females[1].state(1)
malemoves = [2,2,4,4,2,4,4,4,4,4,4,2,2,12]
femalemoves = [6,5,12,12,1]
females[1].rotate(0,1,0,-55)
males[1].rotate(0,1,0,135)
males[1].state(1)
#Set up for throwing man.
males[2].translate(11,0,7)
males[2].state(1)
#Set up for timing.
timebomb = 0
def onkeydown(key):
	if key == '0':
		viz.starttimer(WALKING, .1, viz.PERPETUAL)
	if key == '2':
		females[1].addAction(6)
		males[1].goto(1.6,0,7.7)
		females[1].spinto(0,1,0,-55)
		females[1].state(12)
		viz.starttimer(MALEMEETING,.1)
		viz.starttimer(FEMALEMEETING,.1)
	if key == '4':
		viz.starttimer(THROWINGMAN,.1)
	if key == 's':
		print 's'
		viz.starttimer(TIMING,1, viz.PERPETUAL)
def ontimer(num):
	global gravity, timebomb
	if num == WALKING:
		for agent in walking:
			agentposition = agent.get(viz.POSITION)
			agentgap = vizmat.Distance(agentposition, agent.set[agent.whichturn])
			if agentgap < .1:
				agent.whichturn += 1
				if agent.whichturn == agent.end:
					agent.whichturn = 0
			walk = vizact.walkto(agent.set[agent.whichturn][0],agent.set[agent.whichturn][1],agent.set[agent.whichturn][2])
			agent.addAction(walk)
	if num == MALEMEETING:
		if len(malemoves)>1:
			animation = malemoves.pop(0)
			duration = males[1].getduration(animation)
			males[1].execute(animation)
			viz.starttimer(MALEMEETING, duration-.15)
			males[1].state(animation)
	if num == FEMALEMEETING:
		if len(femalemoves)>1:
			animation = femalemoves.pop(0)
			duration = females[1].getduration(animation)
			females[1].execute(animation)
			viz.starttimer(FEMALEMEETING, duration-.15)
			females[1].state(animation)
	if num == THROWINGMAN:
		males[2].execute(9)
		males[2].execute(1)
		viz.starttimer(THROWINGMAN, 10)
	if num == HOLDVIEW:
		view.translate(-8.5,1.5,-2)
	if num == TIMING:
		print timebomb
		timebomb += 1
		if timebomb == 1:
			onkeydown('0')
		elif timebomb == 3:
			onkeydown('4')
		elif timebomb == 10:
			onkeydown('2')
		elif timebomb == 20:
			onkeydown('3')
		elif timebomb == 30:
			onkeydown('1')
		elif timebomb == 80:
			viz.quit()
viz.starttimer(HOLDVIEW,.001, viz.PERPETUAL)
As an aside, there's an extra female model spawning across the "street" from the spawn point and I can't figure out where the heck she's coming from. If anyone notices before I can find it, I'd appreciate it
Old 01-28-2009, 03:26 PM
Try adding the following line to your script:
viz.eyeheight(0)
The default eye height is 1.8 meters, and it will be added to the Y position of your tracker. Setting it to 0 will simply apply the raw tracking data to the viewpoint height.
Old 01-30-2009, 09:50 AM
Thanks, that fixed everything up for me.
And I found where the random extra avatar was coming from.
export problem bazelaisr Vizard 2 05-28-2008 10:19 AM
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 04:08 PM
PROBLEM: Picture-in-Picture breaks textures?!? vcarlson Vizard 4 10-05-2004 04:22 PM
