Thread Tools Rating: Thread Rating: 2 votes, 1.00 average. Display Modes
Old 08-26-2009, 03:52 AM
snoopy78 snoopy78 is offline
Show flight path of balls
is it possible to show the flight path of objects?
I want to create 2 balls. And afterthat I want to shoot another ball against the two balls.
It is possible to show the trajectories of the balls, before shooting the third ball?
I've got a vector which defines the force of the third ball:
info.object.applyForce( vectorB.vec, 1 )
Or is it possible to show the flown pathes of the balls, after shooting the thrid ball?
Many thanks...
Old 08-28-2009, 03:57 PM
You can use On-The-Fly objects to draw lines. So if you know the beginning and ending point of the balls path, then you could use the following code:
viz.startlayer(viz.LINES)
viz.vertex(beginPoint)
viz.vertex(endPoint)
line = viz.endlayer()
Start_position on animation path ptjt255 Vizard 1 08-24-2009 12:40 PM
smoothing a cubic bezier path just alex Vizard 10 04-22-2009 02:07 PM
Problems with interaction of vizact.turn and animation path Enlil Vizard 3 11-24-2008 05:23 PM
speed on animation path whj Vizard 8 11-17-2008 08:41 PM
How to use 'time function' to control the balls appear separately? znchb Vizard 1 11-03-2008 01:01 PM
