Old 03-09-2010, 02:04 AM
Josh Josh is offline
Head morphs are very slow - some way to prefetch?
Hi all
I noticed that morphs between heads are quite slow. I'm working on a Macbook Pro with 2.5GHz Intel Core Duo and 4GB RAM.
When booting natively into Windows XP (BootCamp), the stuff runs quite fast - only the first morph is "juddering" a little bit, all other morphs work smooth.
But when booting into Windows XP via VMWare Fusion 3 (from within Mac OSX), every morph causes a judder of about 1sec, so often one does't even see the morph but suddenly after the judder the new head appears!
It would be great if I didn't have to boot into native Windows XP every time I want to work with WorldViz... So maybe is there a way to speed up this stuff? Some sort of prefetching these morphs, so they run smoothly?
Thanks for info
Josh
Problems with getting head bone rotation right Enlil Vizard 2 02-13-2009 11:24 AM
Awkward neck/shoulder connection when adding custom head to vcc model. vEsotu Vizard 5 10-09-2008 06:07 PM
problems adding a custom morph head to a custom body Greenwu Vizard 1 07-27-2006 11:32 AM
How to simply texture an avatar's head with a jpeg graphic? vr_boyko Vizard 3 10-26-2004 11:44 AM
animating custom faces: in search of "open_mouth" morphs vr_boyko Vizard 1 09-16-2004 11:30 AM
