Old 02-11-2009, 12:53 PM
Enlil Enlil is offline
Problems with getting head bone rotation right
I am trying to write some code that causes a head to turn and face an object. I looked at the lookat() commands, and those didn't do what we were looking for, so I am writing it from scratch.
Now, I have a routine that takes two points and gives the euler angle that will point the first at the second. I can use this to turn the camera towards an object. However, when I try to do the same thing with the head or neck bone of an avatar, it does not work like I expected.
The code is here:
def GetTargetAngleToFace(position1, position2):
# Find horizontal target angle
x_pos = position1[X_POS] - position2[X_POS]
z_pos = position1[Z_POS] - position2[Z_POS]
horiz_angle = math.degrees(math.atan2(x_pos, z_pos))
#find vertical target angle
vert_x = math.sqrt(x_pos*x_pos + z_pos*z_pos)
y_pos = position1[Y_POS] - position2[Y_POS]
vert_angle = -math.degrees(math.atan2(y_pos, vert_x))
#print "Angles: H: " + str(horiz_angle) + " V: " + str(vert_angle)
return [horiz_angle, vert_angle, 0]
target_euler = GetTargetAngleToFace(self.ObjectToFollowWithHead.g etPosition(mode = viz.ABS_GLOBAL), self.HeadBone.getPosition(mode = viz.ABS_GLOBAL))
self.HeadBone.setEuler(target_euler, mode = viz.ABS_GLOBAL)
where self.HeadBone is the locked 'Bip01 Head' of the vcc_female model that comes with vizard.
What I get is the head tilting to not at all the same euler as target_euler. For that matter, if I just get the current euler of the head and change one element of it, then put it back in with setEuler in viz.ABS_GLOBAL mode, I get a different value when I do a getEuler in viz.ABS_GLOBAL mode. So I figure I am doing something wrong. Could anyone help me here?
Christian
Old 02-13-2009, 09:45 AM
You should be able to use the bone.lookat command to have the head face a certain position. Here is a sample script:
viz.add('tut_ground.wrl')
#Create animating ball
ball.add(vizact.sequence(vizact.goto(-2,1,0),vizact.goto(2,1,0),viz.FOREVER))
#Create male avatar
avatar1 = viz.add('vcc_male.cfg',pos=(-2,0,3),euler=(180,0,0))
avatar1.state(1)
head1 = avatar1.getBone('Bip01 Head')
head1.lock()
#Create female avatar
avatar2 = viz.add('vcc_female.cfg',pos=(2,0,3),euler=(180,0,0))
avatar2.state(1)
head2 = avatar2.getBone('Bip01 Head')
head2.lock()
def UpdateAvatarHead():
	"""Update avatars to look at ball position"""
	pos = ball.getPosition()
	head1.lookat(pos,0,viz.AVATAR_WORLD)
	head2.lookat(pos,0,viz.AVATAR_WORLD)
vizact.ontimer(0,UpdateAvatarHead)
viz.MainView.move(0,0,-5)
Old 02-13-2009, 10:24 AM
We require finer control than lookat provides, but I solved the problem - it appears that mode = viz.ABS_GLOBAL does not work in python, though I used viz.AVATAR_WORLD
Thanks for the help in any case.
Christian
Linking problems with Live Character Frank Verberne Vizard 5 06-04-2008 11:42 AM
Texturing Avatar head problems S.Telemaque Vizard 0 04-01-2007 10:01 PM
Problems Texturing avatar head S.Telemaque Vizard 3 03-27-2007 07:18 PM
problems adding a custom morph head to a custom body Greenwu Vizard 1 07-27-2006 10:32 AM
tracking head rotation orientation VAmanda Vizard 3 09-21-2005 04:57 PM
