Old 02-16-2010, 02:24 PM
imperialkat imperialkat is offline
Moving objects together
How can I move one object based on where another object is moved?
I'm trying to simulate an object in front of a lens and the image it creates. There's one user-controlled object (A) on one side of the lens and another object (B) on the other side. When the user moves A relative to the lens I need B to 1)move a distance X (not necessarily the same distance) in the opposite direction and 2) change size based on its distance from the lens.
Old 02-16-2010, 06:35 PM
Use vizact.onupdate() or vizact.ontimer() to call a function every frame where you get the position of objectA. Based on that position or change from the previous frame you can set the new position of objectB and then scale it based on its distance from the lens.
Old 02-17-2010, 01:43 PM
That helped out a lot. Thanks.
Semi-circle array containing target and distractor objects ptjt255 Vizard 3 08-04-2009 04:09 AM
multiple objects durf Vizard 1 04-10-2009 02:42 PM
Lightwave objects rotation problem hosier Vizard 6 02-13-2009 01:04 PM
Moving multiple objects with ppt durf Vizard 1 02-10-2009 04:03 PM
