Old 02-10-2009, 02:00 PM
durf durf is offline
Moving multiple objects with ppt
Just FYI I am new to python and Worldviz.
So far in my program I have created 3 images. A ball, a pillar, and a stage. My goal is to move the ppt sensor up, which will move the ball straight up and at the same time I want the pillar to move in the opposite direction. So in refrence... as ball moves up on the y axis positively the pillar moves down on the y axis negatively. The stage represtents the x axis which is position on y axis 0 and this represents the starting positions of my ball and pillar.
What I need to know is there any code that will make this happen? is this possible with python? and if so how can I set this code up to work?
feel free to contact me at bdoerfer@uwm.edu
Sorry for no indentations. This forum is not allowing me to. Thanks for any input.
Below is the code that i have used:
import vizinfo
viz.move(0,0,-7)
viz.clearcolor(viz.GRAY)
PORT_PPT = 6
numLights = viz.input('How many lights are you tracking?')
numLights = min(8,numLights)
colors = [
[0, 1, 0.545],
[1, 0, 1],
[0, 1, 1],
[1, 1, 0.545],
[1, 0, 0],
[0, 0.545, 1],
[1, 0.545, 0],
[0.545, 0, 1],
sensors = []
balls = []
labels = []
for x in range(numLights):
#Create Stage
stage = viz.add('tut_ground.wrl')
stagepos = stage.get(viz.POSITION)
#Create sensor
ppt = viz.add('vizppt.dls')
sensors.append(ppt)
#Create ball
ball.scale(1,1,1)
ball.color(colors[x])
balls.append(ball)
ball.link(ppt)
ball.pptColor = colors[x]
ball.curColor = colors[x]
ballpos = ball.get(viz.POSITION)
#Create Pillar
pillar = viz.add('pillarWRL.wrl')
pillar.link(ppt)
pillarpos = pillar.get(viz.POSITION)
def ontimer(num):
for i in range(numLights):
if sensors[i].get()[7]:
ball.color(ball.curColor)
ball.color(viz.BLACK)
def onbutton(obj,state):
if obj == showLight:
for label in labels:
label.visible(state)
elif obj == allWhite:
for ball in balls:
if state:
ball.curColor = viz.WHITE
ball.curColor = ball.pptColor
elif obj == showBad:
viz.killtimer(0)
if state:
viz.starttimer(0,0,viz.FOREVER)
viz.callback(viz.BUTTON_EVENT,onbutton)
def mytimer(num):
print ppt.get()
viz.callback(viz.TIMER_EVENT, mytimer)
viz.starttimer(0,0.5, viz.FOREVER)
Old 02-10-2009, 03:03 PM
So it sounds like the ball just needs to be linked directly to the ppt and for the pillar you just want to negate the y coordinate. You could use the link.swapPos method for that
#create two links
ballLink = viz.link(ppt, ball)
pillarLink = viz.link(ppt, pillar)
#negate the y coordiante
pillarLink.swapPos([1,-2,3])
in the future you can use the code tags to preserve your indentation. Select your code and click on the # icon
Lightwave objects rotation problem hosier Vizard 6 02-13-2009 12:04 PM
tracking with multiple LEDS dan12345 Precision Position Tracker (PPT) 7 04-02-2008 10:44 PM
Problems with making multiple objects from one .wrl? mjabon Vizard 3 07-10-2007 01:23 PM
