Old 02-08-2010, 07:09 PM
hankiwan hankiwan is offline
Question Question about using function
I have a question that how to use a function scipy.stats.rv_continuous.ppf in SciPy package v0.7.
In SciPy Reference Guide, there is description as below.
rv_continuous.ppf(q, *args, **kwds)
Percent point function (inverse of cdf) at q of the given RV.
Parameters:
q : array-like, lower tail probability
arg1, arg2, arg3,... : array-like, The shape parameter(s) for the distribution (see docstring of the instance object for more information)
loc : array-like, optional, location parameter (default=0)
scale : array-like, optional, scale parameter (default=1)
Returns:
x : array-like, quantile corresponding to the lower tail probability q.
I have just started to learn Vizard (Python).
Could you please explain what are *args and **kwds mean? (Do * and ** have additional mean?)
I am confused that what types of parameters are required for using a function rv_continuous.ppf.
If I could get illustrating with examples, it will be a great help to me.
Best regards.
Old 02-15-2010, 10:50 AM
the following link explains *args and **kw
http://pythonfilter.com/blog/what-do...args-mean.html
window.pick function over sub-window omidbrb Vizard 4 10-02-2009 04:23 AM
Timer Question durf Vizard 3 03-31-2009 05:29 PM
Do you know how to send a value for 'pool' to the onActionEnd function? ghazanfar Vizard 1 03-22-2007 10:25 AM
