Old 03-24-2009, 10:18 AM
durf durf is offline
Timer Question
I have a program that I want to run for 10 minutes. In those 10 minutes I want it to check for the time. For the first 3 minutes I want it to run one function. After the 3 minutes expires I want it to start another function for 4 minutes. When that expires I want it to run another function for the remaining 3 minutes.
Do I use a starttimer and have the starttimer equal something and put the 3 functions in a loop so it keeps checking the time?
Im looking for a good way to write this.
Example:
def function1():
"code"
//end of function 1
def function2():
"code"
//end of function 2
def function3():
"code"
//end of function 3
Old 03-24-2009, 10:57 AM
Here is an example that uses the viztask module to control the timing of the 3 different functions:
import viztask
def func1():
	pass
def func2():
	pass
def func3():
	pass
def MainTask():
	#Run func1 for 3 minutes
	timer = vizact.ontimer(0,func1)
	yield viztask.waitTime(180)
	timer.remove()
	#Run func2 for 4 minutes
	timer = vizact.ontimer(0,func2)
	yield viztask.waitTime(240)
	timer.remove()
	#Run func3 for 3 minutes
	timer = vizact.ontimer(0,func3)
	timer.remove()
	#Quit script
	viz.quit()
viztask.schedule( MainTask() )
Old 03-31-2009, 10:18 AM
Ok thanks for that... If I wanted to do it via pressing keys and not a timer how would I do that. I got it to work but I have trouble after I go on to the next function... I can never go backwards.
IE
I press 'a' to initiate def func1():
I then press 's' to iniatiate def func2():
If I press 'a' again I get an error. I assume I need a ontimer or something but I have trouble trying to figure that out.
Any insight would be much appreciated
Old 03-31-2009, 06:29 PM
If you just want to call functions based on keypresses use something like
vizact.onkeydown('a', func1)
vizact.onkeydown('s', func2)
General question and question regarding arrays dan12345 Vizard 1 01-15-2008 11:15 AM
Timer cycling correctly? JMOwens Vizard 2 12-07-2007 10:57 AM
timer question again Elittdogg Vizard 3 10-18-2007 11:29 AM
timer question Elittdogg Vizard 5 10-10-2007 03:49 PM
Timer speed Jerry Vizard 1 12-08-2006 12:01 PM
