Old 02-08-2010, 09:00 AM
dwaik dwaik is offline
rotate camera about an object
hello...
i need to rotate a camera about an object,
i could parent objects to each other, but couldnt parent camera under another object, as another solution i noticed that MainView.pivot() i tried to to move the pivot to that object, but nothing happens.
dont know what to do...
if please someone can help
Old 02-08-2010, 11:02 AM
You can set the camera handler to pivot navigate.
female = viz.add('vcc_female.cfg')
#Setup camera navigation
import vizcam
vizcam.PivotNavigate(center=[0,1,0],distance=5)
Old 02-09-2010, 02:06 AM
thanks alot man that was helpful
rotate object in relation of sth. else Penguin Vizard 6 05-11-2009 09:54 AM
how to pick up the object, move and rotate using mouse nasr Vizard 5 05-05-2009 04:11 AM
Child Object Rotation paulgoldberg Vizard 5 09-05-2006 12:33 PM
