Old 08-03-2009, 12:30 PM
yak yak is offline
linking
import viztask
def DrawLineTask():
	while True:
		#Wait for left mouse butten to be pressed
		yield viztask.waitMouseDown(viz.MOUSEBUTTON_LEFT)
		#Get mouse position
		pos = viz.mouse.getPosition()
		#Create line
		viz.startlayer(viz.POINTS)
		viz.vertexcolor(viz.RED)
		viz.alpha(3)
		viz.vertex(pos[0],pos[1],0)
		viz.ABS_PARENT
		point = viz.endlayer(parent=viz.SCREEN)
		#Create link between mouse position and vertex
		VertexLink = viz.link(viz.Mouse,point.Vertex(1))
		#Wait for mouse button to be released
		yield viztask.waitMouseUp(viz.MOUSEBUTTON_LEFT)
		#Destroy link
		VertexLink.remove()
viztask.schedule( DrawLineTask() )
this code is for drawing points on a 3d model, mainly the male avatar. what I am stuck with is trying to link it to the male while he is animated so after i draw on him it is linked to him even after another action in demonstrated such as walking or picking something up.
Old 08-04-2009, 03:53 PM
You want the point to deform with the avatar mesh? If so, this is not currently possible. You can link the point to one of the avatars bones, but there is no way to get the associated bones from an intersection test.
Old 08-05-2009, 12:55 PM
yak yak is offline
I want the point to stick to the avatar so if hes walking the point is still on him.. i can only link objects i dont know how to link an object with a point....
thanks you for ur help
Old 08-10-2009, 03:01 PM
yak yak is offline
how do u link it to the bone if point isnt an object. I know how to link object to object but not a point or command to object..
import viztask
bone =  viz.add('vcc_male.cfg', alpha= 0.8)
bones = bone.getbone('Bip01 L Thigh')
def DrawLineTask():
	while True:
		#Get mouse position
		#Create line
		viz.ABS_PARENT
		link = viz.link(point.Vertex(1),bones)
		link.preTrans( [0.03,-0.42,0.016] )
		link.preEuler( [-20,0,0] )
		#Destroy link
		VertexLink.remove()
viz.mouse(viz.ON)
Old 08-12-2009, 11:30 AM
Search the docs for "linkbones". There should be an example script that links a node to an avatar bone. However, as I already mentioned, there is currently no way to get a bone object from an intersection hit with an avatar.
Old 08-16-2009, 12:04 PM
yak yak is offline
I dont think a point can be linked......because it isnt really an object. is its for example a .wrl or .3ds or .cgf so i cant really figure out how to link them together.
sensor linking question smith11235 Vizard 6 05-31-2011 04:58 PM
linking view to avatar 5ky1ine Vizard 7 04-21-2009 11:03 AM
Linking problems with Live Character Frank Verberne Vizard 5 06-04-2008 11:42 AM
Body linking nige777 Vizard 3 03-06-2008 02:17 PM
Linking avatar 'bones' to a position tracker. zachhendershot Vizard 3 11-19-2003 09:26 PM
