Old 07-17-2008, 12:33 PM
smith11235 smith11235 is offline
sensor linking question
Hey,
I've found some other posts/examples that seem to take a complicated approach to what I am trying to do and was hoping if someone could tell me if the following simple approach was possible:
I have an emagine 3d visor and also a polhemus motion tracker.
I have successfully linked the main view to both of these devices separately as follows:
polhemus = viz.add('polhemus.dle);
patriot = polhemus.addPatriot();
link = viz.link(patriot,viz.MainView);
And also in another script:
emagin = viz.add('emagin.dls');
viz.link(emagin, viz.MainView);
However, what I would like to do is control the 'head view' of the world with the emagine sensors, and the movement with the Patriot sensor ideally with something similar to the following:
viz.link(emagin, viz.HeadView);#attach users 'eyes' to visor
link = viz.link(patriot,viz.Body);#let user move independently of where they are looking
I am hoping that this is just a matter of linking the correct objects which have so far eluded me to the sensors.
Any pointers would be greatly appreciated.
Thank you in advance
Old 07-17-2008, 12:37 PM
To be clear, you want the orientation of the viewpoint to come from the emagin and the position to come from the patriot?
Old 07-17-2008, 12:38 PM
yes, that would be correct.
Old 07-17-2008, 12:41 PM
Then the simplest solution would be to use the viz.mergeLinkable command. Have a look in the docs for an explanation. Here is some simple code showing how to use it:
#Combine position of patriot and ori of emagin into one sensor
tracker = viz.mergeLinkable(patriot,emagin)
#Link tracker to main viewpoint
headLink = viz.link(tracker,viz.MainView)
Old 07-24-2008, 10:28 AM
Thanks for your help. That worked great, I had missed that function while looking through the help files.
Old 05-30-2011, 05:57 AM
francesco.alett francesco.alett is offline
hi! i have a an emagin z800 3d visor and a polhemus tracker too; both are working (can see the desktop in the eye-screen an so on...) i'm trying to run the script as you suggested, but i read this error message in the output box when launching:
polhemus.dle Polhemus Extension
** ERROR: Failed to connect to a Patriot/Liberty: Device not found
** ERROR: Failed to create extension sensor with polhemus.dle
** ERROR: Link failed (source linkable is invalid)
emagin.dls eMagin v2.0
** ERROR: Could not connect to eMagin device. Error: 80000017
could you help me please? thank you very much
Old 05-31-2011, 05:58 PM
Vizard is not able to connect to either the Polhemus or Emagin sensors.
Polhemus - Test with the following script:
polhemus = viz.add('polhemus.dle')
If you get errors verify that you can connect to the Polhemus device in PiMgr. When running Vizard, PiMgr should be closed.
Emagin - Try the following:
viz.link(emagin,viz.MainView)
Do you get errors? Have you installed the USB drivers for the Emagin sensor?
General question and question regarding arrays dan12345 Vizard 1 01-15-2008 11:15 AM
viztask question asimbh Vizard 1 11-20-2007 10:12 AM
to rephrase my question... shai Vizard 2 10-27-2004 11:55 AM
Lots of Question Karthi Vizard 4 02-20-2004 07:42 PM
Basic Joystick Navigation Question Plasma Vizard 2 01-29-2004 08:08 PM
