Old 07-21-2009, 09:49 AM
Chrissy2009 Chrissy2009 is offline
Draw a triangle instead of a point
how can I draw a traingle at the end of my line, instead of points?
I've done this:
	        viz.startlayer(viz.LINES)
		viz.linewidth(5)
		viz.vertexcolor(viz.RED)
		viz.vertex(punkt1)
		viz.vertex(punkt2)
		viz.startlayer(viz.POINTS)
		viz.pointsize(10)
		viz.vertex(punkt2)
		vec = viz.endlayer()
Is there a possibility to draw triangles instead of points?
Old 07-21-2009, 10:46 AM
Instead of using viz.POINTS you can use viz.TRIANGLES and specify the position of each vertex. Example:
viz.startlayer(viz.TRIANGLES)
viz.vertex(p1)
viz.vertex(p2)
viz.vertex(p3)
Draw Vector in viewpoint lookat direction Chrissy2009 Vizard 2 05-30-2009 01:50 AM
Draw Line between Points Chrissy2009 Vizard 2 05-13-2009 05:42 AM
Incoming floating point values Rachel Vizard 1 02-12-2008 04:09 PM
data glove navigation arielasso Vizard 6 10-24-2007 03:15 PM
looking at a point vadrian Vizard 5 06-07-2005 06:43 PM
