Old 06-02-2005, 04:21 PM
vadrian vadrian is offline
looking at a point
i want to make an avatar look at an absolut point in space (e.g. have all the students in a class look at the teacher). avatar.lookat() makes the entire body point, while avatar.heatto() creates an animation using yaw/pitch/roll. i want this:
teacher = [2, 3, 4]
avatar.lookatpoint(teacher)
def lookatpoint(self, point):
    self._headbone = self.getbone('skel_Head')
    self._headbone.lock()
    self._headbone.lookat(point, viz.ABSOLUTE_WORLD)
this doesnt' seem to work, but i think you get the point. so how do i do this?
Old 06-02-2005, 04:50 PM
Here is a sample script that should help you out:
male = viz.add('male.cfg')
head = male.getbone('skel_Head')
head.lock()
dummy = viz.add(viz.GROUP)
ball.spin(0,1,0,45)
ball.translate(2,0,0)
ball.center(-2,0,0)
def ontimer(num):
	dummy.translate(head.get(viz.POSITION,viz.ABSOLUTE_WORLD))
	dummy.lookat(ball.get(viz.POSITION,viz.ABSOLUTE_WORLD))
	head.rotatequat(dummy.get(viz.QUAT), viz.ABSOLUTE_WORLD)
viz.starttimer(0,0,viz.FOREVER)
I'll add the lookat command for bones in the next release.
You're two for two today. Are there any other features you want me to add to the next release?
Old 06-03-2005, 03:51 PM
do i have to make the dummy node, move it, and adjust the head using timers and quats? or is there a simpler way considering that i will have 20 people in the simulation that either need to be looking at the teacher, at someone/thing else, or straight ahead (which would be too many hard-coded functions for my taste).
Old 06-03-2005, 04:52 PM
Just create a global dummy node and then have a function that pretty much contains the code in the timer. Here's a cleaned up version of the sample code:
#You only need a single global dummy node
	dummy.translate(self._headbone.get(viz.POSITION,viz.ABSOLUTE_WORLD))
	dummy.lookat(point)
	self._headbone.rotatequat(dummy.get(viz.QUAT), viz.ABSOLUTE_WORLD)
Old 06-07-2005, 05:11 PM
i even made your code a bit more specific to absolute-world location, but it still doesnt work. all the heads look to the same absolute-local point.
_dummy.translate(self._headbone.get(viz.POSITION,viz.ABSOLUTE_WORLD), viz.ABSOLUTE_WORLD)
_dummy.lookat(point, 0, viz.ABSOLUTE_WORLD)
self._headbone.rotatequat(_dummy.get(viz.QUAT), viz.ABSOLUTE_WORLD)
is there another way to go about this? nothing seems to work with avatar heads like it does with regular objects.
Old 06-07-2005, 05:43 PM
Let me know if this example script works. There should be two avatars in front of you who will be tracking a ball that is moving back and forth across the screen.
viz.add('tut_ground.wrl')
ball.add(vizact.sequence(vizact.goto(-2,1,0),vizact.goto(2,1,0),viz.FOREVER))
avatar1 = viz.add('male.cfg')
avatar1.translate(-2,0,3)
avatar1.rotate(180,0,0)
avatar2 = viz.add('female.cfg')
avatar2.translate(2,0,3)
avatar2.rotate(180,0,0)
def lookatpoint(avatar,point):
	_headbone = avatar.getbone('skel_Head')
	_headbone.lock()
	dummy.translate(_headbone.get(viz.POSITION,viz.ABSOLUTE_WORLD))
	dummy.lookat(point)
def ontimer(num):
	pos = ball.get(viz.POSITION)
	lookatpoint(avatar1,pos)
	lookatpoint(avatar2,pos)
viz.move(0,0,-5)
