Thread Tools Rating: Thread Rating: 3 votes, 2.33 average. Display Modes
Old 04-08-2009, 10:24 PM
DBurks2818 DBurks2818 is offline
Making buttons appear in scenes
Hey all, I was wondering someone could help me? I'm trying to make a scene-based menu and I can't seem to get buttons and sliders (basically anything that isn't text) to appear in the different scenes. Also, I can't get an image to show up in them either. What am I doing wrong?
Thanks in advance for any help provided.
viz.clearcolor(0,0,1)
song = viz.add('War Room.mp3')
song.play()
song.volume(1.0)
########################Title Page##############################
#Add New Game transition button to scene 1 (Main Menu).
New_Game=viz.addButton()
New_Game.translate(0.321,0.572)
vizact.onbuttondown( New_Game, viz.scene, 2 )
#Add Tutorial transition button to scene 1 (Main Menu).
Tutorial=viz.addButton()
Tutorial.translate(0.321,0.419)
vizact.onbuttondown( Tutorial, viz.scene, 3 )
#Add Options transition button to scene 1 (Main Menu).
Options=viz.addButton()
Options.translate(0.321,0.503)
vizact.onbuttondown( Options, viz.scene, 4 )
#Add Exit button to scene 1 (Main Menu).
Exit=viz.addButton()
Exit.translate(0.321,0.316)
vizact.onbuttondown( Exit, viz.quit )
#vizact.onkeydown( '1', viz.scene, 1 )
#vizact.onkeydown( '2', viz.scene, 2 )
#vizact.onkeydown( '3', viz.scene, 3 )
#vizact.onkeydown( '4', viz.scene, 4 )
########################Tutorial################################
vizact.onkeydown(' ', viz.window.hideHTML )
s1 = viz.addButton(viz.WORLD, 3)
s1.translate(.045,.082)
s1.visible(viz.OFF)
s2 = viz.addButton()
s2.translate(.380,.082)
s2.visible(viz.OFF)
s3 = viz.addButton()
s3.translate(.670,.082)
s3.visible(viz.OFF)
def Help(obj,state):
	if obj == Tutorial:
		if state == viz.pick:
			viz.window.displayHTML( '1.htm' )
			s1.visible(viz.ON)
			s2.visible(viz.ON)
			s3.visible(viz.ON)
viz.callback(viz.BUTTON_EVENT,Help)
Title = viz.addText('TUTORIAL', viz.SCREEN, 3)
Title.translate(.319, 0.898)
Title.color(0,0,0)
Basic = viz.addText('BASIC MOVES', viz.SCREEN, 3)
Basic.translate(.066, 0.066)
Basic.color(0,0,0)
Basic.fontSize(45)
Main = viz.addText('MAIN MENU', viz.SCREEN, 3)
Main.translate(.401, 0.066)
Main.color(0,0,0)
Main.fontSize(45)
Special = viz.addText('SPECIAL MOVES', viz.SCREEN, 3)
Special.translate(.690, 0.066)
Special.color(0,0,0)
Special.fontSize(45)
def onButton(obj,state):
    if obj == s1:
        if state == viz.DOWN:
    elif obj == s3:
            viz.window.displayHTML( '2.htm' )
    elif obj == s2:
            viz.window.hideHTML()
            s3.remove()
viz.callback(viz.BUTTON_EVENT,onButton)
########################Options#################################
def music(obj, pos):
	song.volume(1.0*pos)
viz.callback(viz.SLIDER_EVENT,music)
#Title: Options
_Options = viz.addText( 'Options', viz.SCREEN, 4 )
_Options.setScale(1.0, 1.0 )
#Position
_Options.translate( .093, .856)
#text_2D.color
_Options.color( 0.753, 0.753, 0.753 )
#Title: Graphics
_Graphics = viz.addText( 'Graphics', viz.SCREEN, 4 )
_Graphics.setScale(0.700, 0.700 )
#Position
_Graphics.setPosition( .150, .688)
#text_2D.color
_Graphics.color( 0.753, 0.753, 0.753 )
#Title: Effects
Effects = viz.addText( 'Effects', viz.SCREEN, 4 )
Effects.setScale(0.700, 0.700 )
#Position
Effects.setPosition( .150, .618)
#text_2D.color
Effects.color( 0.753, 0.753, 0.753 )
#Title: Music Volume
mv = viz.addText( 'music volume', viz.SCREEN, 4 )
mv.setScale(0.700, 0.700 )
#Position
mv.setPosition( .150, .469)
#text_2D.color
mv.color( 0.753, 0.753, 0.753 )
##slider,pos,orientation
music = viz.addSlider(viz.WORLD, 4) #Add a slider.
music.set(1.0)
music.setPosition(.669,.488) #Set its position.
music.setScale(1,1)
music.ticksize(1,1) #Increase the size.
#Title: Main Menu
_Exit = viz.addText( 'Main Menu', viz.SCREEN, 4 )
_Exit.setScale(0.900, 0.900 )
#Position
_Exit.setPosition( 0.239, 0.182 )
#text_2D.color
_Exit.color( 0.753, 0.753, 0.753 )
#exitBtn
Mainmenu = viz.addButton(viz.SCREEN, 4)
Mainmenu.translate(.146,.206)
Mainmenu.setScale(4.521, 1.398 )
#Title: Size1
#640 X 380
_Size1 = viz.addText( '640 X 380', viz.SCREEN, 4 )
_Size1.setPosition( .589, .726)
_Size1.setScale(0.600, 0.600 )
#color
_Size1.color( 0.753, 0.753, 0.753 )
#s1
s1 = viz.addButton(viz.SCREEN, 4)
s1.translate(.569,.745)
s1.setScale(1, 1 )
#Title: Size2
#1024 X 768
_Size2 = viz.addText( '800 X 600', viz.SCREEN, 4 )
_Size2.setPosition( .452, .634)
_Size2.setScale(0.600, 0.600 )
#color
_Size2.color( 0.753, 0.753, 0.753 )
#s2 btn
s2 = viz.addButton(viz.SCREEN, 4)
s2.translate(.429,.651)
s2.setScale(1, 1 )
#Title: Size3
#640 X 480
_Size3 = viz.addText( '1024 X 768', viz.SCREEN, 4 )
_Size3.setPosition( .742, .634)
_Size3.setScale(0.600, 0.600 )
#color
_Size3.color( 0.753, 0.753, 0.753 )
#s3 btn
s3 = viz.addButton(viz.SCREEN, 4)
s3.translate(.720,.653)
s3.setScale(1, 1 )
#Resolution function
def Res(obj,state):
    if obj == s1:
            viz.window.setSize(640, 380) #Sets to this 640x380
    elif obj == s2:
            viz.window.setSize(800, 600) #Sets to this 800x600
    elif obj == s3:
            viz.window.setSize(1024,736) #Sets to this 1024x736
viz.callback(viz.BUTTON_EVENT,Res)
########################Exit################################
#Insert Exit Page here later
Old 04-09-2009, 10:16 AM
Nevermind! Figured it out.
s1 = viz.addButton(viz.Scene3)
Should've used that instead of:
s1 = viz.addButton(viz.SCREEN, 3)
Duh
Old 04-09-2009, 01:56 PM
Alright, new question. Why does the screen sometimes crash when trying to implement a slider? I still can't get it to appear without messing up the 'run' window.
Old 04-09-2009, 03:02 PM
My guess is it has something do with your function that is called when a slider event occurs. Could you narrow down this code to show a slider that replicates the problem. What kind of error are you getting?
Old 04-09-2009, 03:25 PM
music = viz.addSlider(viz.scene4) #Add a slider.
music.set(1.0)
music.setScale(1,1)
This is what's causing the error, or any time I try to implement any slider at all. When I do, it will either show a 'broken window' where I can only see the title bar and the actual window will be transparent (and I can see the code environment through it), or the window/game will freeze when I put the slider in a different scene in the window and try to switch to that scene.
I just tried to implement a slider on another computer and it works fine, and the slider is the only problem on this one. I wonder what the problem is exactly?
Help With Creating Menus and Buttons for a Chess Game RodRSpv Vizard 1 02-27-2009 03:12 PM
Arranging Scenes in Correct Order utepbereed Vizard 1 11-21-2008 10:19 AM
What are the options for making a movie of a Vizard world? Karla Vizard 1 05-13-2008 11:56 AM
Buttons Not rendering to both Eyes in 3d shivanangel Vizard 2 05-24-2007 07:58 AM
environment maps, scenes, and you! vadrian Vizard 1 01-12-2005 05:04 PM
