Old 04-06-2009, 04:23 AM
Moh200jo Moh200jo is offline
Walking to many directions.
Hi every one, my avatar will walk to unknown distances and directions. I tried to rotate her while she is walking but the code does not response. I am still plying with the following code.
HTML Code:
avatar.setPosition(0,0,5)
pos = avatar.getPosition()
ss=1
def myKeyboard(key):
	ss=1
	gg=5
	if key == viz.KEY_UP:
		ss=ss+5
		walk_Forward = vizact.walkTo([pos[0], pos[1],pos[2]+ss])
		avatar.addAction(walk_Forward)
	if key==viz.KEY_LEFT:
		gg=gg + 10
		rotate=vizact.spin(0,1,0,gg,1)
		avatar.addAction(rotate)
	if key == viz.KEY_DOWN:
		ss=ss+5
		walk_Forward = vizact.walkTo([pos[0], pos[1], pos[2] - ss])
viz.callback(viz.KEYBOARD_EVENT,myKeyboard)
Any help would be appreciated.
Old 04-06-2009, 08:33 AM
If you want two actions to occur simultaneously you can add them to different pools. If you don't specify the pool the default is 0 and it will be added to the end of the object's queue or waiting list. This adds rotate to pool 1
avatar.addAction(rotate, pool = 1)
Old 04-06-2009, 09:10 AM
Oh, thanks Jeff!
But when the avatar stopped for awhile, and then she wants to continue with same direction the code takes her to the other direction (z-axis).
I have tried to increment x-axis but wasn’t practically.
As well as I tried to make the mainview to follow the avatar, when this has been done, the key function does not work probably
HTML Code:
import viztask
mainview=viz.clearcolor(viz.SKYBLUE)
avatar.setPosition(0,0,9)
#view = viz.MainView
#link = viz.link(avatar, view)
#link.preTrans([0,-.5,-5])
ss=1
	ss=1
	gg=5
	global walk_Forward
		ss=ss+5
		avatar.addAction(walk_Forward,pool=1)
		gg=gg + 10
		ss=ss+5
Old 04-06-2009, 11:52 AM
If you want to link the avatar to the viewpoint, you could use keyboard navigation like this to move the viewpoint and avatar forward and turn side to side.
viz.add('tut_ground.wrl')
avatar.state(1)
import viztracker
keyTracker = viztracker.Keyboard6DOF(forward=viz.KEY_UP,backward=viz.KEY_DOWN,turnRight=viz.KEY_RIGHT,turnLeft=viz.KEY_LEFT)
view = viz.MainView
viz.link(keyTracker, view)
link = viz.link(view, avatar)
link.preTrans([0,-1.8,2])
#change the state when avatar stops or starts
def checkState():
	global pos
	if pos == avatar.getPosition():
		avatar.state(1)
		avatar.state(2)
vizact.ontimer(.1, checkState)
Old 04-07-2009, 05:44 AM
That is brilliant, but still there is small problem, which is the speed. Once the avatar’s speed has been increased, the user will realize that the mainview is moving not the avatar. So how can I handle this issue?
Please just add this line to your code and then you will see what will happen:
HTML Code:
avatar.speed(5)
Thanks a lot for all your efforts
Old 04-07-2009, 06:56 PM
This creates a KeyboardCamera object. Use the sensitivity method to scale the movement and turning speeds. You can increase the speed of the avatar animation when the camera speed increases.
avatar.state(1)
import vizcam
camera = vizcam.KeyboardCamera(forward=viz.KEY_UP,backward=viz.KEY_DOWN,turnRight=viz.KEY_RIGHT,turnLeft=viz.KEY_LEFT)
viz.cam.setHandler(camera)
view = viz.MainView
def changeSpeed(key):
	if key == '1':
		avatar.speed(1)
		camera.sensitivity(1,1)
	elif key == '2':
		avatar.speed(1.2)
		camera.sensitivity(2,1)
	elif key == '5':
		avatar.speed(1.5)
		camera.sensitivity(5,1)
viz.callback(viz.KEYDOWN_EVENT,changeSpeed)
def checkState():
	global pos
		avatar.state(1)
		avatar.speed(1)
		avatar.state(2)
Old 04-08-2009, 06:25 AM
it works! thanks Jeff for your help.
Walking viewpoints TrashcanPatrol Vizard 5 05-02-2013 09:14 AM
Walking Function Moh200jo Vizard 2 02-24-2009 10:07 AM
How to make avatars to follow terrain while walking? yyang Vizard 1 08-04-2008 02:54 PM
Walking avatars --> collision detection? sjroorda Vizard 3 10-13-2005 04:47 AM
