Old 02-24-2009, 03:08 AM
Moh200jo Moh200jo is offline
Walking Function
Hi guys
Are there any examples for walking to specific targets?
For example: the targets are 4 boxes; the avatar should walk to reach them and then stop for 1s in front box (4 stops).
I used viz.move (x, y, z, speed, target distance)
But the problem is in target distance; If targets are as follows:
10, 20, 30, 40 all theses distances are measure from 0 point and move function measures this from 0 point; the avatar can do just the first target correctly.
Any ideas for this?
Alternatively, is there function can do this?
Old 02-24-2009, 05:00 AM
this is a sample :
room=viz.add('court.ive')
box = viz.add('box.wrl')
room.setPosition(0,0,25)
boxes=[]
for i in [15,30]:
	box.setPosition(0,1,i)
	boxes.append( box )
avatar=viz.add('vcc_male.cfg')
avatar.setPosition(0,0,3)
i=0
def keyboard(key):
	if key=='w':
		boxtar=boxes[i]
		target=boxtar.getPosition()[2]
		avatar.state(2)
		walk=vizact.move(0,0,1,target-3)
		avatar.addAction(walk)
		global i
		i+=1
viz.callback(viz.KEYBOARD_EVENT,keyboard)
Old 02-24-2009, 11:07 AM
speed and distance
I found the problem and it is that the avatar position times the speed; for example : if the box position is 2 and the avatar starts from 0 with speed 2 his position will be at 4 not 2 although the order like this viz.move(0,0,2,2)
Are there any thoughts?
Documentating function names aaThomas Vizard 5 05-15-2007 10:50 AM
Do you know how to send a value for 'pool' to the onActionEnd function? ghazanfar Vizard 1 03-22-2007 11:25 AM
timers and director function Jerry Vizard 1 06-22-2006 10:47 AM
Walking avatars --> collision detection? sjroorda Vizard 3 10-13-2005 05:47 AM
node3d.center function tavaksai Vizard 3 08-13-2004 12:05 PM
