Old 03-31-2009, 09:50 AM
durf durf is offline
stopping a function
I have def func1() and def func2() that do not run on timers of there own. I have a def maintask() that controls when each of the def() will start. The problem I am having is once func1() time has expired and func2() timer starts func1() keeps runnning.
def MainTask():
	#Run func1 for 10 seconds
	timer = vizact.ontimer2(0,0,func1)
	yield viztask.waitTime(10)
	timer.remove()
	#Run func2 for 10 seconds
	timer = vizact.ontimer2(0,0,func2)
	timer.remove()
	#Quit script
	timer = vizact.ontimer2(0,0,func3)
	yield viztask.waitTime(viz.FOREVER)
viztask.schedule( MainTask() )
how do I stop func1() from running once func2() has started?
I can supply more code if need be. Just looking for an example
Old 03-31-2009, 04:45 PM
masaki masaki is offline
in order to kill a vizact timer, use the following code:
timer.setEnabled(viz.OFF)
if you want to kill a viztask function use the following code:
task = viztask.schedule( sometask() )
task.kill()
-masaki
Walking Function Moh200jo Vizard 2 02-24-2009 10:07 AM
Documentating function names aaThomas Vizard 5 05-15-2007 09:50 AM
Do you know how to send a value for 'pool' to the onActionEnd function? ghazanfar Vizard 1 03-22-2007 10:25 AM
timers and director function Jerry Vizard 1 06-22-2006 09:47 AM
node3d.center function tavaksai Vizard 3 08-13-2004 11:05 AM
