Old 10-22-2008, 10:14 AM
vNicolef vNicolef is offline
Making objects "grow"
Hi there,
I'm trying to place a mole on an avatar's face so that over time you can see the mole gradually grow bigger. Would this be done with an animation or a timing function?
Old 10-22-2008, 05:54 PM
If the mole is a 3d object, then you can use the vizact.size action to make the object gradually bigger. For example the following code will make the mole object grow to 3x its size over 10 seconds:
mole.addAction( vizact.size([3,3,3],10,viz.TIME) )
Old 11-06-2008, 03:15 PM
how to kill timer
Thanks, that helps a lot. Is it possible to kill this action if I want it to stop prematurely?
Old 11-06-2008, 03:33 PM
Nevermind... I figured it out. Thanks!
Improve performance with large number of onthefly objects? Fox5 Vizard 7 04-28-2008 05:19 PM
Problems with making multiple objects from one .wrl? mjabon Vizard 3 07-10-2007 01:23 PM
Sound objects removal Andrey Vizard 1 05-04-2007 02:13 PM
putting objects on the screen jargon Vizard 7 05-24-2005 11:31 AM
