Old 05-04-2007, 07:34 AM
Andrey Andrey is offline
Sound objects removal
How to remove sound objects (in order to use the number of sound files beyond 100 limit - <viz>.clearcache did not help)? Object.remove() method does not work with audio objects.
Andrey
Old 05-04-2007, 02:13 PM
You will need to upgrade to Vizard 3.0. It has the ability to delete audio objects with the <audio>.remove() command.
