Old 07-03-2008, 10:55 AM
Jerry Jerry is offline
New Viz version broke intersense
After installing the most recent Vizard, version 3.10.0028, I get this
error on all scripts using the intersense plugin
ISD_GetTrackerConfig failed
** ERROR: Intersense device has no active stations
Help!
Old 07-03-2008, 02:18 PM
Vizard uses a special build of the isense.dll that is supposed to fix some problems. Can you try downloading the 4.0.4 version of isense.dll located at http://www.isense.com/support.aspx?id=373? Replace the existing isense.dll file in the Vizard/bin directory with the downloaded version and see if that fixes the problem. If so, we might need to rollback the included driver that comes with Vizard until InterSense provides a more stable one.
Old 07-07-2008, 10:19 AM
FYI, yes, the 4.0.4 version works. Looks like you should roll back.
Can I get real time Intersense tracking data from another computer on the network? GoldenSun Vizard 4 04-30-2008 07:42 PM
using demo with intersense G-Chan Vizard 1 02-06-2006 02:05 PM
Intersense Server & 3d Max Hodge1620 Vizard 4 10-26-2005 01:39 PM
Importing into Trial Version drahcir Vizard 1 08-03-2005 07:27 AM
intersense orientation jargon Vizard 2 05-14-2005 04:55 PM
