Old 04-05-2008, 03:14 PM
wouters wouters is offline
Intersense Script
I am using using an Intersense tracker to provide head tracking data to Vizard. Currently, the tracker and Vizard interface works correctly once the tracker has been configured. Unfortunately, in order to configure the tracker I need to send a script to the tracker before it will send back correct data. I can do this manually before I run Vizard, but I am wondering if there is a way to automatically send a configuration script to the tracker using Vizard.
Also, how do you figure out what the different commands are for your tracker in the sensor.command() function?
Thanks for your help!
Leah
Old 04-07-2008, 11:16 AM
The documentation for the Intersense plugin describes all the available commands (http://www.worldviz.com/vizhelp/Old_...se_Plug-In.htm).
The Intersense driver will automatically load a configuration file when a tracker connection is first opened. Here is the description from the InterSense API documention:
When a tracker is first opened, library automatically looks for a configuration file in current directory of the application. File name convention is isenseX.ini where X is a number, starting at 1, identifying one tracking system in the order of initialization.
The InterSense API has a function to send a configuration file to a tracker and another function to send a script to a tracker. I'm not sure what the difference between their configuration file and script is. Does the configuration file support your needs?
Old 04-07-2008, 01:59 PM
Thumbs up
Thank you. The configuration file works just fine.
Leah
starting Vizard from a Python script hotspur1 Vizard 12 06-12-2019 01:03 PM
using demo with intersense G-Chan Vizard 1 02-06-2006 03:05 PM
Intersense Server & 3d Max Hodge1620 Vizard 4 10-26-2005 02:39 PM
intersense orientation jargon Vizard 2 05-14-2005 05:55 PM
Passing arguments to vizard script hotspur1 Vizard 7 05-02-2003 03:03 PM
