Old 03-25-2008, 11:52 AM
Lotar Lotar is offline
BoundingBox() question
I noticed that when some object has one or more children, this function always returns bounding box that contains parent and all its children.
So, my questions is, what should I do if I want to get only parent's bounding box and (this is important) I want to get if _after_ I attach some child to it ?
Thank you.
Old 03-25-2008, 04:55 PM
You can use the optional node parameter of the getBoundingBox function to specify the specific subgraph that you want to compute the bounding box of. This will work as long as the child nodes don't have a subgraph with the same name. Another workaround would be to temporarily detach the children from the parent while computing the bounding box, then reattaching them using the node.unparent/parent commands.
Stereo Overlap question JMOwens Vizard 2 01-08-2008 08:54 AM
question about yaw, pitch, roll TunTun Vizard 2 05-23-2007 12:46 PM
to rephrase my question... shai Vizard 2 10-27-2004 10:55 AM
Lots of Question Karthi Vizard 4 02-20-2004 06:42 PM
