Old 02-19-2004, 07:47 PM
Karthi Karthi is offline
Lots of Question
I need help with quite a few things... i'm not really sure how to do any of them
1) I need to periodically pause my VR world. I want the "simulation" to pause and not stop and restart, as i want it to continue from the point it left off.
(As i am creating a psychology experiment)
2) I want to create a text box which just appears when the "simulation" is paused. This test box has a question. The user uses a joystick to select an approprate respone.
3) I would like to log the responses in an excel file for anlysis. I would like to log, the time of the simulation pause as well as the response as the questions remain the same.
Cheers
karthi
Old 02-20-2004, 11:08 AM
Hi Karthi,
1) To pause your simulation you would just need to kill all your timers. Then restart them when you want to resume the simulation. I went ahead and added this feature to Vizard, so it should be available in the next version.
2) You can use the viz.choose command to ask the user a question, however they wouldn't be able to use the joystick to select the answer.
3) There is an example in the tutorial folder that does just this. The file is called tutorial_savedata.py. It simply logs each key press the user makes and the time of the key press into a file.
Good luck!
Old 02-20-2004, 02:46 PM
Viz.choose
HI!
My supervisor really would like the 'participants' to choose their responses using a joystick, as they cannot use the mouse. I know about the 'sid'. Is there a tutorial about how to use this?
Cheers
karthi
Old 02-20-2004, 03:24 PM
Hi Karthi,
Here's a script I just wrote that does what you want. It displays a question with two choices. Use the joystick pad to select an option. The selected option will be colored red. Use the trigger button to make your choice.
import sid
CHECK_JOYSTICK_MOVE = 0
CHECK_JOYSTICK_CLICK = 1
HIGHLIGHT_COLOR = [1,0,0]
NONHIGHLIGHT_COLOR = [1,1,1]
Question = viz.add(viz.TEXT3D,'Is Vizard Awesome?',viz.SCREEN)
Question.translate(0.5,0.8)
Question.alignment(viz.TEXT_CENTER_CENTER)
Choices = ['Yes','No']
TextList = []
for x in range(0,len(Choices)):
	text = viz.add(viz.TEXT3D,Choices[x],viz.SCREEN)
	text.translate(0.3,0.6-(0.1*x))
	if x == 0:
		text.color(HIGHLIGHT_COLOR)
		text.color(NONHIGHLIGHT_COLOR)
	TextList.append(text)
SelectedChoice = 0
def mytimer(num):
	global SelectedChoice
	if num == CHECK_JOYSTICK_MOVE:
		y = sid.get()[1]
		if y < -0.3:
			TextList[SelectedChoice].color(NONHIGHLIGHT_COLOR)
			SelectedChoice = (SelectedChoice + 1) % len(Choices)
			TextList[SelectedChoice].color(HIGHLIGHT_COLOR)
			viz.starttimer(CHECK_JOYSTICK_MOVE,0.5)
		elif y > 0.3:
			SelectedChoice = (SelectedChoice - 1) % len(Choices)
			viz.starttimer(CHECK_JOYSTICK_MOVE,0.01)
	elif num == CHECK_JOYSTICK_CLICK:
		if sid.buttons() & 1:
			if SelectedChoice == 0:
				print "You have good taste"
				print "I just plain don't like you"
			viz.starttimer(CHECK_JOYSTICK_CLICK,0.5)
			viz.starttimer(CHECK_JOYSTICK_CLICK,0.01)
Old 02-20-2004, 06:42 PM
I will try this!
Cheers
Karthi
