Old 09-12-2006, 11:57 AM
hotspur1 hotspur1 is offline
Collision detection between objects
I'd like to detect when two objects collide so they stick together (e.g., robot hand grabs object). With v2.53 I've been using the following
<node3d-1>.collidemesh()
<node3d-1>.collidingwith(<node3d-2>,0) # This returned a 1 if meshes intersected.
I see that the syntax has changed slightly to collideMesh, is the collidingwith method still included in v3? Or is there a new way to do this?
Old 09-12-2006, 12:02 PM
The current Beta version of 3.0 does not implement the collidingwith function. However, there is still a way to detect whether two nodes are colliding. The viz.phys.intersectNode() function will return a list of all the nodes that a node is currently colliding with. Example:
if node2 in viz.phys.intersectNode(node1):
    print 'Node 1 is colliding with Node 2'
Old 09-12-2006, 12:29 PM
Great - that did the trick - thanks.
Old 12-02-2006, 10:42 AM
giancamati giancamati is offline
Talking document
Where can I find a document explaining all these changes?
g.a.
Old 12-05-2006, 12:17 PM
We are still working on the documentation. You can always look at the source, aka the viz.py file.
