Old 04-14-2010, 02:03 PM
Josh Josh is offline
Wait for function to return?
Hi all
I want to stop the execution of my script until a function returns.
The idea is to stop the script when starting a task, where the user has to press a key (P), and as soon as he presses the key, the script should continue.
class Experiment:
        # This method is called somewhere...
	def start_green_face_task(self):
		self.avatar_to_morph().make_green_face()
		self.test_reaction_time() # Here the code should stop until this method returns (when the user presses P)! But how can this be achieved?
		self.end_green_face_task() # This method should be called *after* the user presses P!
	def test_reaction_time(self):
		while True:
			yield self.viztask.waitKeyDown('P', d)
			return
	def end_green_face_task(self):
		self.avatar_to_morph().remove_green_face()
Sadly I don't get it to work... I tried stuff like
yield self.test_reaction_time()
or
self.viztask.schedule(self.test_reaction_time())
but somehow this doesn't do what I need...
Thanks very much for help!
Josh
Old 04-15-2010, 07:11 AM
Please, this is very important for me... Anyone??
Old 04-15-2010, 01:43 PM
*Push* (I'm sorry, but it's very important that I get this to work asap)
Old 04-15-2010, 02:45 PM
IGoudt IGoudt is offline
Exactly *what* does not work? On which line does the program do other than you expect it to do?
Following changes might not work, but at least it should call test_reaction_time() correctly. Issue is that end_green_face_task() will run at the same time (I think). You can move that method call to test_reaction_time() as well, but why do you need a viztask for a key event? You can also register the P button with the function end_green_face_task()
class Experiment:
		viztask.schedule(self.test_reaction_time()) # Here the code should stop until this method returns (when the user presses P)! But how can this be achieved?
		yield viztask.waitKeyDown('P')
Old 04-15-2010, 03:11 PM
I believe the following code should do what you want:
class Experiment:
		viztask.schedule( self.test_reaction_time() )
		yield viztask.waitKeyDown('P') # Here the code should stop until this method returns (when the user presses P)! But how can this be achieved?
return variable from keypress function starbug Vizard 2 01-07-2010 12:14 PM
return IDE to default config billjarrold Vizard 2 12-10-2009 07:05 PM
Sit, stay, wait? EnvisMJ Vizard 1 05-20-2009 05:36 PM
Unexpected carriage return vizmaster Vizard 3 01-23-2007 01:46 PM
plug-ins that return quaternions hotspur1 Vizard 2 02-05-2004 08:47 PM
