Old 01-18-2007, 12:59 PM
vizmaster vizmaster is offline
Unexpected carriage return
When adding a texture from a file any \r in the filename is seen as a carriage return.
C:\Tester\retest is seen as C:\Tester\
etest
To get around this I either add a different character to the before the "r" or an additional \. Is this suppose to be how it works?
VizMaster
Old 01-18-2007, 01:05 PM
You can also use the following to allow backslashes in strings:
path = r'C:\Tester\retest'
Placing an r before the string tells python not to translate backslash expressions.
Old 01-18-2007, 01:09 PM
Forgot to mention, you can also use forward slashes.
Old 01-23-2007, 12:46 PM
I will give the suggestions a try. I forget the I am dealing with an interpretive language.
VizMaster
